I would like to suggest the ability to view the structure of the directory with a tracing line, similar to breadcrumb IIRC. Also, the 'Folder' window to automatically center on the current directory. Color of the line could be modified. As shown below under other programs, a vertical line follows the directory structure, which for me, makes it easier to follow where I am especially with the size of my directories and work in them.
Xnview without directory tracing.
Xnview with directory tracing.
Programs with visible directory tracing.
Directory structure tracing
hawaii
hawaii
Re: directory structure tracing
Up.
It would also be nice to have the folders left adjust. Sometimes when a tree becomes too long, the folder structure is invisible.
