On Function "Copy to" (Kopieren nach) missing Option "New Folder" (Neuer Ordner)
Tamaleus
Post by Tamaleus »
Hi
I really hope I did not oversee existing Topic to that.
I'm working currently with "XnView MP Windows, Version 1.4.3 64bits (Feb 25 2023), Libformat version 7.138, on Windows 10 Home, 22H2.
Question: Is there no Option (Button) to add "New Folder" (Neuer Ordner) when copying/moving from Main Window selected File(s) and Right-Click ("Kopieren nach ... Alt+C" / "Verschieben nach ... Alt+M") into another "Directory"/Folder?
From within Windows Explorer I'm used to have the Option to allways add "New Folder" when copying or moving one or more Files from one to another Destination. Or didn't I just see it! And, Extra-Question: What does "Erweitern"? On my XnView it doesn't do anything. Or what I'm doing wrong?
Tks + Best Rgds
Tamaleus
Re: On Function "Copy to" (Kopieren nach) missing Option "New Folder" (Neuer Ordner)
yes will be better
Tamaleus
Post by Tamaleus »
Beg your pardon, Pierre, however do not understand yr Answer "yes well be better".
need to be added
