Images get disappear from the folder.
yaraq
Post by yaraq »
Hello!
I want to thank each and everyone who took part to make this amazing software!
Its simple, user friendly, lots of languages, customizable UI, changable hot-keys. Thank you!
But as the name of the topic says, there is something annoying about this program. I faced this problem just twice or maybe more, and i just did not noticed it the other times i was using XnView.
Well it's pretty simple. I click the folder with lots of images in it. Once it opened the blue progress bar in the right down corner starts to fill. When it hits 100% some of the images gets disappear from that folder. I still be able to see the dissapeared images by using windows explorer, but they're invisible in XnView. I recorded the video to explain the problem in visual way.
https://youtu.be/heduh8n_RqU.
It would be awesome to hear some recomendation how to fix this!
Thanks!
Re: Images get disappear from the folder.
which 'filter by ' do you have?
yaraq
Post by yaraq »
xnview wrote: Thu Apr 06, 2023 6:58 am which 'filter by ' do you have?
It's custom by default. I tried different filters, it's still the same
'all' you have same things? what do you have in 'settings>File list>Custom'?
yaraq
Post by yaraq »
xnview wrote: Thu Apr 06, 2023 12:15 pm 'all' you have same things? what do you have in 'settings>File list>Custom'?
Chose 'all' filter and still missing some of the images.
That's my settings:
are you sure that image files disappear? The number of objects changes (in statusbar)? Do you use 'sort by>Name'?
yaraq
Post by yaraq »
xnview wrote: Thu Apr 06, 2023 2:32 pm are you sure that image files disappear? The number of objects changes (in statusbar)? Do you use 'sort by>Name'?
Im pretty sure some of the images dissapear from the folder in XnView, but not from the windows explorer.
Looks like the problem is gone for now. I did not do anything actually, but it fixed for now :)
Thank you for your feedback, anyway :*
