Is there a way to select two thumbnails and compare them side by side?
mrwul
Post by mrwul »
Likely it is totally impossible, but nonetheless - just asking...
I'd like to select two thumbnails
then r-click XnViewMP compare or something
and they show up side by side in 1 window so I can compare them more accurately.
As said, likely impossible...
Thanks !
Re: Is there a way to select two thumbnails and compare them side by side?
Tools>Compare?
mrwul
Post by mrwul »
Right, but then from Windows Explorer (or better Directory Opus) context menu.
