Choose Default Country Code in IPTC Editor
BuckSkin
Post by BuckSkin »
Regarding the Country Code selector in the IPTC Editor.
Seeing as how 99% or more of the images that most of us will add a Country Code to will be in a single country, it sure would be nice if we had the ability to choose the country code once and for all and set it as our default country code that will never change unless we ourselves change it.
It is an eye straining time consuming chore to have to repeatedly scroll through the many choices and choose the correct Country Code.
Thank you for reading.
Re: Choose Default Country Code in IPTC Editor
you means replacing the long list with an edit text?
BuckSkin
Post by BuckSkin »
xnview wrote: Fri Apr 07, 2023 10:21 am you means replacing the long list with an edit text?
Yes; that would work.
Or let us choose our country and it stay the chosen country, like a permanent option.
Thanks.
BuckSkin
Post by BuckSkin »
xnview wrote: Fri Jun 16, 2023 4:04 pm This problem is supposed to be fixed in XnView MP 1.5.0 beta. Please check and confirm the bug fix here.
I checked this in 1-5-0 beta 1 and could see no difference than in the behavior of all previous versions - unless there is something I am not seeing or doing right.
Thanks.
UPDATE: I just now checked this in beta 4 and can not see any difference - am I missing something ?
you can change in xnview.ini [iptc] ccode= for default
BuckSkin
Post by BuckSkin »
xnview wrote: Wed Jul 05, 2023 6:30 am you can change in xnview.ini [iptc] ccode= for default
Please forgive my ignorance; where do I find this and how do I go about changing it ?
Thanks.
Settings>Integration>Paths - open config file
BuckSkin
Post by BuckSkin »
THANK YOU !
