1.4.3 - viewer - does not save to Guetzli JPEG
XnViewMP 1.4.3 64bit
Viewer
2. open any picture
3. press CTRL+SHIFT+S to Save as
- select 'JPG - Guetzli JPEG' format
- press Save
Save dialog closes, but no new file appears
Re: 1.4.3 - viewer - does not save to Guetzli JPEG
:bugconfirmed: Thanks to your detailed description I can reproduce on highres image
xnview wrote: Thu Apr 20, 2023 7:19 am ..I can reproduce on highres image
i cannot save any file into this format, even this one:
the only difference between tiny and large files - progress bar thats shows for longer on large ones
fixed in 1.5.0
