1.4.3 - crop toolbar - selection autorotation and clipboard hotkeys
XnViewMP 1.4.3
Viewer
few issues with crop toolbar selection autorotation and clipboard hotkeys
2. open any picture
3. press SHIFT+X to open crop toolbar
4. make any selection
Issue A
5. rotate selection
6. press CTRL+X
selection rotates to 0degree before cutting
Issue B
5. press CTRL+C
no data will be copied to clipboard
I would expect bigger rectangular being copied to clipboard with background color (as per settings), like this:
Issue C
5. copy some image to clipboard in another app (eg mspaint)
6. press CTRL+V in xnview
image will be pasted from clipboard
7. make another selection and press CTRL+V
nothing will be pasted from clipboard
Issue D
5. rotate selection
6. scroll to prev/next image
selection will remain, but its rotation will be reset
Suggestion A
For the sake of consistancy all clipboard shortcuts (CTRL+X / C / V) shall be either disabled or enabled, not partial.
If enabled they shall work as usual - cut/copy/paste.
Suggestion B
add Rotation degree textbox to set value precisely at crop toolbar
inspired by Image Crop: the crop box can be rotated, and I can't reset, nor input the crop rotation degree with 0
Suggestion C
improve key modifier support (regular/crop-toolbar selection):
  • add SHIFT+Rotation to limit rotation to 8 directions (✳, 45deg steps)
  • add SHIFT+Move to limit movement to 8 directions (✳, 45deg steps)
  • fix CTRL+Move strange/unstable effect:
    - sometimes does not move at all
    - sometimes move vertical only
    - sometimes selection jumps to original point after CTRL release
    probably last one is desired effect, but imho, CTRL should not affect movement/rotation behaviour
Related
Re: 1.4.3 - crop panel - selection autorotation and clipboard hotkeys
