1.4.3 - join - crash fitting large images
XnViewMP 1.4.3 64bit
Windows11 64bit (22H2), display resolution 3840x2160, win scaling 150%
Browser
app crash fitting large images
Join test images with the following settings - app will crash
join_crash_test_img.zip
(637 Bytes) Downloaded 150 times
masterjp
Re: 1.4.3 - join - crush fitting tall image
Post by masterjp »
I can confirm your program crash.
The problem of the joining process is the large yellow line picture with extreme big size (1000 x 20.000 pixels)!
All the other files are much smaller (100 pixel height). If you resize the yellow picture to a smaller size (e.g. 10.000 pixels height),
the joining will work perfectly.
Maybe it is a workaround for your problem.
PC: Intel 8700k + Asus Z370-F + 16 GB RAM G.Skill + Asus RTX 3050 OC + Samsung SSD
OS: Windows 10 Pro 64bit 22H2 |
GFX: XnViewMP 1.8.7 | XN-View 2.52.0 | XnConvert 1.104.0 | Adobe Photoshop Elements 2024 | Elements XXL 11 | Paint.Net 5.1.7
Re: 1.4.3 - join - crash fitting large images
yep, I have updated post with additional info
no worries, thats just for testing purposes, but thanks for care )
fixed in 1.5.0
it takes few minutes to join into huge pic 401000x20000x24, but cannot save it - app creates 0size file and shows error message.
