"Showinfo" not work when open image from explorer from second time
Hi, i want to report a bug of latest version of xnview mp (1.4.3) with windows 10:
my settings :
general=> mode when starting with a file : "viewer-fullscreen"
general=> allow only one instance
view=> info=>"always show in fullscreen" ticked
view=> fullscreen=> "show info" ticked
how to reproduce :
-open image in xnviewmp in the first time : "show info" work
-leave xnview mp open, switch to window explorer and open another image (image should open in fullscreen mode) => " show info" not work , there is no info show (while info expected to be shown)
(for more clearly, bug only appears when open image in 2nd time in explorer and onwards)
Thanks
my settings :
how to reproduce :
Thanks
Re: "Showinfo" not work when open image from explorer from second time
i can't reproduce. What do you have in Interface>Tab settings?
it looks like xnviewmp writes (some?) settings to .ini file on close only, so your new instance uses unchanged .ini
hi ,thanks for the replyxnview wrote: Thu Apr 13, 2023 8:44 am i can't reproduce. What do you have in Interface>Tab settings?
here 's mine :
also when i encounter the issue (info not show), if i press f11 to switch to window mode then press f11 again, the info got show again
i also include the settings of info tab : my info settings is custom, like you see in the image : {Directory}{Filename}***{Size}
and here is my xnview.ini file
https://drive.google.com/file/d/1OrhwuL ... sp=sharing
i think not because i set the info settings and close already logn time ago, and now i still can reproduce the issue
here is link to my xnview.ini
I just tried with latest version (1.4.4), this bug still exist
Thanks
Thanks
on Windows 10, with your .ini, i follow the steps but info is always here on second tab
do you mean second time? because with my settings, there is only 1 tab allowedxnview wrote: Fri Apr 21, 2023 12:32 pm on Windows 10, with your .ini, i follow the steps but info is always here on second tab
if i open another image second time while xnviewmp not in fullscreen mode, the info still shows,
with me the info only disappear when i open second image while xnviewmp still in fullscreen
here 's some additional detailed info
step1 : when i open image on the first time, it opened in fullscreen, and info show
step2 : then i use windows + d to show desktop (leave xnviewmp open) , then open image by windows explorer
=> it should open in fullscreen and the info not show
but if in step 1, if i open the image not in fullscreen mode,or change to window mode, then open another image, the info still shows (like i said above)
Thank you very much
i'm so anxious for the updated version
This problem is supposed to be fixed in XnView MP 1.4.5. Please check and confirm the bug fix here.
It works like a charm . thank you very much
