White line at the bottom of cropped PNGs
rogi
Post by rogi »
White line is shown at the bottom of a png image after it is cropped.
There is no line in the image itself, it is only displayed in XnViewMP at 100% scale (not present if the image is opened in another software or a view scale is changed to other value than 100%).
Re: White line at the bottom of cropped PNGs
do you use windows font scaling? could you send me the file?
rogi
Post by rogi »
I use a second monitor, so my system UI scale is 125%.
Problem persists in v.1.5.0.
could you send the output png file? what do you have in Settings>View?
