In the metadata viewing panel, under the Exif tab, when I right-click any field, even under the GPS heading, and choose "Copy All", it copies everything EXCEPT the GPS info.
I have discovered, however, that I can hi-lite the GPS header/separator and right-click and "Copy This Item" and it will copy all of the GPS entries and only the GPS entries, which is often quite handy.
However, sometimes it would be nice for "Copy All" as first described, to Copy All including the GPS information at a single click.
Thanks for reading.
Bug or Not? = Copy All to Clipboard
Re: Bug or Not? = Copy All to Clipboard
i can't reproduce, if i use 'Copy all' on Exif tab, GPS data are copied too
