1.4.4 - export - crash on Best Fit
XnViewMP 1.4.3-1.5.0 64bit
Export dialog
crash on Preview Best Fit
2. open relatively wide image (>450px), eg test one
The attachment test_img_plane_8.zip is no longer available
3. press CTRL+ALT+S to open Export... dialog
- tick 'Auto refresh' checkbox
- increase dialog height, so the image has black areas on top and bottom
4 OPTIONAL. click 'Zoom 100%' button
5. click 'Best Fit' button
app will crash
Re: 1.4.3 - export - crash on Best Fit
i can't reproduce, you are able to always make the crash?
yep, still an issue on 1.4.4
try "if app does not crash" alternative steps
really strange, i can't
i have video :D
(recorded at 100% win scale, but it does not affect this issue)
masterjp
Post by masterjp »
I tested it on Windows 10 and can not reproduce the problem.
PC: Intel 8700k + Asus Z370-F + 16 GB RAM G.Skill + Asus RTX 3050 OC + Samsung SSD
OS: Windows 10 Pro 64bit 22H2 |
GFX: XnViewMP 1.8.7 | XN-View 2.52.0 | XnConvert 1.104.0 | Adobe Photoshop Elements 2024 | Elements XXL 11 | Paint.Net 5.1.7
maybe this test image will help
upd: crashes 1.4.3 and 1.4.4 for me
test_img_20kx20k.zip
(437 Bytes) Downloaded 270 times
masterjp
Post by masterjp »
Thanks for the test file.
I am using the latest Version of XnViewMP 1.4.4 and could not reproduce your problem.
In your post you say you are using Version 1.4.3.
Did you get the crash with the latest version, too?
Please try it again.
yeah, same crash in 1.4.4
maybe win11 invovled somehow, as I do not have win10 to test
masterjp
Re: 1.4.4 - export - crash on Best Fit
Post by masterjp »
Does your computer have enough ram?
I tested it with 8 GB and 16 GB physical RAM.
2pc: intel/amd, both 32gb ram, ssd
1laptop: intel, 16gb ram, ssd
all win11 and crash on each one of them
also icons look a little bit pixelated and behave different when squeezed
maybe its related somehow
another example with Replace dialog
open Import & sort dialog and import test file second time
1. press Original zoom
2. press Best fit
app will crash
test_file.zip
(1.17 MiB) Downloaded 215 times
not able to reproduce, and the crash dump seems to be invalid
<=0.98.3 - not crashing
>=0.98.4 - crashing
100% reproducible
5 more crash dumps from 1.5.4
export_crash.zip
