1.4.3 - viewer - keyboard shortcut not working ALT+ENTER
XnViewMP 1.4.3 64bit
Viewer
2. open any image
3. press ALT+ENTER (main one aka Return)
nothing happens
4. press ALT+ENTER (on numpad)
opens file Properties...
I assume all ALT+ENTER combinations suppose to open file Properties...
Re: 1.4.3 - viewer - keyboard shortcut not working ALT+ENTER
ALT+Return & ALT+Enter are different
Ok, but why there is no 'Properties' shortcut for ALT+RETURN (it works in XnView Classic and File Explorer)?
What about notebooks or 75% keyboards that have no numblock and thus Enter key?
imho, by default, ALT+RETURN shall have the same shortcut as ALT+ENTER
user0 wrote: Wed Apr 12, 2023 8:28 am imho, by default, ALT+RETURN shall have the same shortcut as ALT+ENTER
I can't have ALT+RETURN and ALT+ENTER, you can change the shortcut in settings
If it is not possible to have 2 shortcuts for 1 action, then, imho, 'Properties' shall have ALT+RETURN shortcut by default.
Just because ENTER key is not always available on keyboard.
Also it is not possible to assign ALT+RETURN as shortcut to any action.
user0 wrote: Wed Apr 12, 2023 4:49 pm If it is not possible to have 2 shortcuts for 1 action, then, imho, 'Properties' shall have ALT+RETURN shortcut by default.
Right. See issue for current status and some details.
no problem here :?
fixed in 1.4.4
