When I click Draw, the screen looks like attachment 1. If I click on "T" (text), for instance, it looks like in Attachment 2. Then, I can not figure out how to get the OK and Cancel buttons back. Problem or easy solution?
Hans L
Draw and its icons background
Hans L
Re: Draw and its icons background
Buttons are on the right
Hans L
Pierre, this pertains to a monitor standing on its short edge (kinda' "portrait" mode) and its display orientation being portrait, and scale being 175 %.
When I click Draw, the buttons (OK & Cancel) are visible down right, but when I click "Add text", the buttons are outside the visible field in the window, and I cannot scroll horizontally right to access them (I can click "Restore Down" and see the buttons, though). Now, while in "Add text" mode, if I do click "Restore Down" and then "Maximize? (same icon), the OK and Cancel buttons become visible.
I assume that we all would like the OK/Cancel buttons to be visible after the initial click on "Add text".
Best regards,
Hans L
PS. And there is no Minimize icon in the window. How come?
Best regards,
Hans L
what is the width of your screen?
