1.4.3 - settings - assigning Shortcuts polishing
XnViewMP 1.4.3 64bit
Settings
UX improvement when assigning Shortcuts
2. press F12 to open Settings
3. goto Shortcuts (Interface > Shortcuts tab)
4. select any action, eg '100%'
5. click on key_entry_field (with *)
6. press any already assigned key, eg F2
message will appear "This shortcut is already assigned.."
7. press ESC to close message
Issue A
- message closes and appears again
I guess it should not appear again.
Issue B
- Shortcut radio button selects None, but previous value (blue box) remain intact (* in our case).
I guess previous value should be populated in radio button and key_entry_field (Default and *, in our case).
Re: 1.4.3 - settings - assigning Shortcuts polishing
I can reproduce the issue B, but have not 2 times the dialog
retested on 1.4.4 - issue A is fixed
fixed in 1.5.0b1
