1.4.4 Show info in slideshow
Galizia
Post by Galizia »
XnViewMP 1.4.4 32bits Portable
Windows 10 22h2 32bits
Hi, if i assign letter  i  as shortcut for cmd_showinfo, this shortcut doesn't work in slideshow mode.
It works properly in XnView Classic 2.51.2 32bits
Thank you very much!
Re: 1.4.4 Show info in slideshow
1.5.0b3
it works in a strange way
all default settings (show info is on)
A
- add files
- run slideshow
- press i
- slideshow will close
B
- add files
- run slideshow
- wait until slide changes
- press i
- slideshow will restart with Information off
expected behaviour:
it sould affect only Info state (on/off), nothing else
will be fixed in b4
1.5.0b4
A, B - fixed
however
C - transition effect applies to Info that looks messy.
its better to add settings to disable that behaviour and just pop info immediately
D - pressing i with transition effects enabled causes slide to reload
