PDF on MacOS
alamothe
PDF on MacOS
Post by alamothe »
How to get PDF working on MacOS?
MacOS: Ventura on Apple Silicon
XNView MP Version 1.4.3 64bits
I installed ghostscript with
brew install ghostscript
~ $ gs --version
10.01.1
~ $ which gs
/opt/homebrew/bin/gs
It does not want to open any PDF nor display any thumbnail. Any help appreciated.
Please quote to develop this feature.
Re: PDF on MacOS
Ghostscript 64-bit?
If so, there have been a number of times been compatibility issues with newly released GS versions, but I don't recall anyone has reported one recently.
As far as I know, with default program setting PDF files should open in the viewer, although browser thumbnails might have to be enabled. It will also usually be necessary to increase the Ghostscript rasterisation DPI setting in order to obtain a good quality image, in the viewer File > Format settings, at least in the Linux installation.
Re: PDF on MacOS
i've tried to install the same version on MacOS ARM, and it works correctly with 1.4.4
Could you try to start XnView from a terminal?
alamothe
Re: PDF on MacOS
Post by alamothe »
Works if launched from the terminal!! 🎉
open /Applications/XnViewMP.app
Maybe there should be a config option for where to find ghostscript? Or look also in /opt/homebrew/bin/gs since I assume this is where 90% of people will have it on MacOS.
Thanks for your help!
Re: PDF on MacOS
yes perhaps /opt/homebrew/bin/ is not in the PATH by default
attaboyBrad
Re: PDF on MacOS
Post by attaboyBrad »
Is there a way to make PDFs on XnViewMP for Mac Sonoma work without launching XnViewMP/XnConvert from the terminal like this?
I'm in the exact same situation where I can launch either Xn app from terminal with "open /applications/xnviewmp.app" and work with PDFs but otherwise I get no previews of PDFs and get errors like 'not an image' or 'File Can't be Loaded!'.
All software is fully updated on an M1 Mac Studio. XnView and XnConvert are installed from the website (not app store), I've tried installing Ghostscript via both HomeBrew and MacPorts to no avail, I've tried adding lines to ...zsh or whatever that is to make sure HomeBrew is in my $PATH, and restarting, etc.
I'm at a loss after banging my head against this for a couple of hours now, and I bet it's as simple as running a command or two... I just don't know what command to run.
Re: PDF on MacOS
ghostscript is in your $PATH, and it doesnt work?? Currently i search for a better solution
attaboyBrad
Re: PDF on MacOS
I believe ghostscript is in my path...
This is what I get from >echo $PATH:
/opt/homebrew/bin:/opt/homebrew/sbin:/Library/Frameworks/Python.framework/Versions/3.9/bin:/Library/Frameworks/Python.framework/Versions/3.11/bin:/Library/Frameworks/Python.framework/Versions/3.10/bin:/opt/local/bin:/opt/local/sbin:/opt/homebrew/bin:/opt/homebrew/sbin:/usr/local/bin:/System/Cryptexes/App/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/local/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/appleinternal/bin:/Library/Apple/usr/bin:/opt/homebrew/bin
This is what I get from >which -a gs:
/opt/local/bin/gs
I'm afraid I may have made a mess of PATH in trying to get this to work, but I'm still in the position of PDFs working in Xn apps when launched from terminal, and not working otherwise.
Grateful for any guidance you can provide, and grateful for XnView and XnConvert, without which I could not have accomplished some important projects.
nr084
Re: PDF on MacOS
Post by nr084 »
hey. still having this problem. xnview on mac os opens pdf only when launched from terminal. i think that need to add gs to path systemwide, but dont know how to do it. may be the configuration path of ghostscrpit can help?
cjyaaaaa
Re: PDF on MacOS
Post by cjyaaaaa »
Who will save us poor souls who can only open the software from the terminal?
cjyaaaaa
Re: PDF on MacOS
Post by cjyaaaaa »
cjyaaaaa wrote: Thu Feb 05, 2026 5:20 pm Who will save us poor souls who can only open the software from the terminal?
Solved, terminal input
sudo launchctl config user path /opt/homebrew/bin:/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin
