1.4.4 Possible bug in list_folder= setting
Galizia
Post by Galizia »
XnViewMp 1.4.4 Portable 32Bits
Windows 10 22h2 32Bits
Hi, i'm not sure if this is a bug but at least is a cuorious behaviour.
If after closing XnViewMP i make a backup of Xnview.ini and this backup
contain this setting  list_folder=C:\PHOTOS  the next time that i launch
XnViewMP Xnview.ini is modified and now shows  list_folder=C:HOTOS
Best regards.
Re: 1.4.4 Possible bug in list_folder= setting
yes it's normal, xnview.ini use / and not \
