Scroll speed/offset for cursor keys
ChangeMe9000
Post by ChangeMe9000 »
It seems the classic version had support to adjust the scrolling offset for the cursor keys. This is something I'd very much like to have (the current offset is set way too low in my opinion.)
Reference:
viewtopic.php?f=34&t=11989&p=186912
Hanswurst
Re: Scroll speed/offset for cursor keys
Post by Hanswurst »
+1 from me.
And / or using shift as modifier for fast scrolling is a suggestion that suits this feature well.
you would like to scroll more thumbnail lines in a single key press?
maybe Shift+scroll - 'page' size scroll (the size of visible thumbnail lines)
Hanswurst
Post by Hanswurst »
For me personally it's about scrolling in zoomed images.
Hanswurst
Post by Hanswurst »
I checked it.
Scrolling a zoomed picture with Shift + Arrow is now working and considerably faster than just using Arrow.
Works as expected.
Thank you!
