1.4.4: Tab key bindings not working on macOS
Corax
Post by Corax »
XnView: MP 1.4.4
OS: macOS 13.1 (Apple Silicon)
The standard Ctrl-Tab and Ctrl-Shift-Tab key bindings for switching tab do nothing.
Effect: nothing
1. Start XnView in viewer mode (for instance), open an image (automatically in a new tab).
2. Try to return to the the viewer using Ctrl-Tab or Ctrl-Shift-Tab.
Actual behaviour (bug): nothing happens
Expected behaviour: the tab is switched
Note: this issue was previously reported (albeit in the wrong section) by @ttg in this topic.
Re: 1.4.4: Tab key bindings not working on macOS
right, currently it's an issue with Qt API
