Not auto refresh
alee001
Not auto refresh
Post by alee001 »
Not auto refresh after close find simulate file in case of deleted pictures, If you batch rename all pictures in folder will occur error. (Must press F5 to auto refresh)
XnView MP Windows
Version 1.4.4 64bits (Apr 17 2023)
FKCapitalism2
Re: Not auto refresh
Post by FKCapitalism2 »
Unfortunatley XnView MP is not made for "automatic" updates there are many situations in which it does not update... :?
could you describe a way to reproduce?
alee001
Post by alee001 »
xnview wrote: Wed May 03, 2023 6:27 am could you describe a way to reproduce?
The situation is the same as the process I described.
Steps to reproduce would be helpful...
alee001
Post by alee001 »
Step as following:
1) Open a folder in xnview
2) Compare the inside pictures according to similar files
3) Assume 50% similarity and compare
4) Obtain a similar result of two pictures in a certain group
5) Delete one of the pictures
6) Press Cancel to exit the comparison of similar files
7) In the folder of xnview, press Ctrl+A to select all the pictures
8) Press F2 to rename batches
9) An error pops up (as shown in the figure)
