XnViewMP 1.4.4 64bit
Viewer Level...
histogram does not updates
2. open image
3. [OPTIONAL] press H to show Histogram for reference (it works OK)
4. press L to open Levels...
5. modify any parameter
histogram does not change
[feat] viewer - Level's histogram does not updates
FKCapitalism2
Re: 1.4.4 - viewer - Level's histogram does not updates
In XnView MP histogram (h key) does change when adjusting levels.
Do you mean histogram inside levels windows does not change?
I see same behavior in Photoshop levels adjustment, histogram inside levels adjustment windows stays the same even if you change levels, i think its intentional.
right, thanks!
looks like a feature, not a bug
