Convert raw as close to embedded thumbnail as possible.
FKCapitalism2
Post by FKCapitalism2 »
Hello, i have three RAW images taken with different exposure, need to convert to JPEG using XnView MP's - Batch Convert dialog.
No matter what settings i choose in Settings > General Formats > Read > Camera RAW can't get conversion result that will be a close match the JPEG embedded in the RAW files by the camera.
RAW files https://www.upload.ee/files/15159653/RAWs.zip.html
Re: Convert raw as close to embedded thumbnail as possible.
You are reporting that the Embedded preview option isn't working correctly?
As a workaround, you could probably select a larger option and then include a custom Resize action in the actions you use.
FKCapitalism2
Not reporting bug, only asking if someone knows combination of options to make it convert close to original preview.
For example when i open in Photoshop and save without applying any settings i get identical look to preview embedded in RAW file only colors more saturated, but XnView MP modify image too much.
