Hi there,
I think there is a bug in XNView 1.4.4 when I execute a batch conversion with an "BORDER" action in it...
I use the "Batch convert ..." command to generate a frame around my edited tiff photos. Those photos are resized and then a frame is generated using the "BORDER" action. The converted photos are saved in jpg format.
Until version 1.4.3 of XNView this works fine, since I have upgraded to version 1.4.4 the EXIF data (information in section IMAGE) of the generated jpg is missing. The option to preserve metadata is checked.
Could you please have a look at this!?! Do you need further information?
Best regards
Ludger
P.S. I use Windows 11 64Bit
1.4.4 - EXIF-Data [Image] is deleted after a Border action in Batch convert
Re: 1.4.4 - EXIF-Data [Image] is deleted after a Border action in Batch convert
Merci beaucoup, Pierre!
This problem is supposed to be fixed in XnView MP 1.4.5. Please check and confirm the bug fix here.
I have verified that the issue is fixed in XNViewMP 1.4.5
Best regards
Ludger
Best regards
Ludger
