Set tag after viewing/closing images
zamfir1235
Post by zamfir1235 »
I m using XnView MP on macOS Ventura. I would like to add a tag after i open ,view and close an image file. This is basically to keep track of images viewed.
I generally click to open a image file , view it and then close it. After i close it , is there any way to set a tag automatically via XnView. may be via an addon or a plugin.
Any suggestions?
Gwenael Q.
Re: Set tag after viewing/closing images
Post by Gwenael Q. »
I don't know about any automatic tagging ...
My only suggestion would be: click to open a image file , view it and then Ctrl+T before closing it...
rating, color label or tag?
zamfir1235
Just the tag.
e.g if I define a tag say "Viewed" and set "Viewed" as default tag. Then if I open , view the image and close it. It should apply the "Viewed" tag to the file. However, if tag is already applied. It should not apply the tag again.
If there was an option in settings like -> Apply tag after closing image and possibly give selection of tags. That would be awesome.
if not, is there any way to do it via plugins on macOS?
no sorry no such feature
