1.4.4 - viewer - High zoom quality - state out of sync
XnViewMP 1.4.4 64bit
Viewer - Zoom - High zoom quality
state is out of sync between Viewer menu and Settings combobox until app restarted
2. open any image and zoom-in max to see effect
3. press F12 to open Settings
- set 'High zoom quality ' to Never (View>View tab)
- press OK
3. in Viewer goto View menu
'High zoom quality ' is still checked (until app restarted)
4. click on 'High zoom quality '
smoothing filter will be applied to the image, though in Settings it will retain 'Never' option
Related
Re: 1.4.4 - viewer - High quality zoom state out of sync
This problem is supposed to be fixed in XnView MP 1.4.5. Please check and confirm the bug fix here.
Re: 1.4.4 - viewer - High zoom quality - state out of sync
fixed in 1.4.5
(settings in Settings affets Viewer menu item, but not the other way)
as far as I got the idea for settings that duplicated in multiple places:
  • Settings
    is persistant storage
  • Viewer/Browser state
    is session only and do not affect Settings
    it is OK as long as its consistant and applies to all other cases as well
