Add metadata summary info panel
anthonysikorski
It would be nice to have a panel that summarizes the main camera exif infirmation in big font. Attached is an example from DXO Photolab.
- ISO
- Shutter speed
- aperture
- focal length
- camera
- lens
- ISO
- Shutter speed
- aperture
- focal length
- camera
- lens
Re: Add metadata summary info panel
a new panel before 'Properties' or datas before 'File' in properties?
anthonysikorski
Both would work I think
how about
Examples
Mockup (lazy one)
as a separate panel
- separate panel
OR
- join it with histogram
Examples
Mockup (lazy one)
as a separate panel
you have already some info in 'Properties' at the end
Perhaps moving it at the begin, and more graphical?
anthonysikorski
Yes the information is there but it’s small and hard to read. I think the new panel should not replace the current detailed information but be an addition to access key information easily.
This shall be separate panel, not another tab inside Info panel.
Its better not to break tabs' list (table-a-like) structure as in future you may deside to add filter functionality to Info panel tabs that will not work with "more graphical" items.
ps: histogram shall be separate panel as well
This problem is supposed to be fixed in XnView MP 1.6.3. Please check and confirm the bug fix here.
done in 1.6.3
cicciobello
Some voices black-on gray. Definitely a problem with my custom style settings?
which theme do you use?cicciobello wrote: Tue Dec 12, 2023 6:25 pm Some voices black-on gray. Definitely a problem with my custom style settings?
the issue is quite old - not all elements are updated on theme switch, some remain unchanged until app is restarted
cicciobello
I use a custom theme (style_sheet.qss). I used elements from various parts/origins. I don't know exactly how it works, but I managed to get something that works quite well, albeit with some problems.
The problem is not resolved by restarting MP. I have been using this theme for various releases.
