1.4.4 - viewer - zoom mode inherits from fullscreen
XnViewMP 1.4.4 64bit
Viewer
Issue described in disconnect zoom-fullscreen from zoom-browser still exists:
risky7 wrote: Fri Dec 02, 2022 10:34 am - present situation is that when I switch from fullscreen to viewer than zoom from fullscreen is applied to viewer which is not correct behaviour, they should be completely independent
"Last used" is default "Auto image size" option for both modes (normal and fullscreen) in Settings
2. open any image
3. set "Auto image size" to "No fit" in Viewer
4. OPTIONAL
- close xnview and reopen image
- check if settings is saved in Viewer. It is.
5. press F11 to open image fullscreen mode
6. press F11 to exit fullscreen mode
7. press ←/→ or scroll to go to the prev/next file
zoom mode will be - "Fit to window, large only"
It can be caused by default "Last used" option, it looks like it is ether:
- global, than why it works one direction only (fullscreen→normal, but not normal→fullscreen)
- local, than viewer-normal should not inherit viewer-fullscreen's zoom settings
Expected behaviour:
Viewer-normal to retain "No fit" option as in Settings it is set to "Last used"
Related
Re: 1.4.4 - viewer - zoom mode inherits from fullscreen
This problem is supposed to be fixed in XnView MP 1.4.5. Please check and confirm the bug fix here.
fixed in 1.4.5
