Extract thumbnail from catalog.
FKCapitalism2
Post by FKCapitalism2 »
I have situation when image was deleted from hard disk, however its still inside Thumbs database of XnView MP and shows as on of four thumbnails on folder that view trough XnView MP.
How can i locate that thumbnail inside the Thumb.db file and extract it using DB Browser for SQLite?
Path is "C:\Users\Dell\Downloads\RAW Preview\" name of the image file i don't know, how do i look for it inside Thumbnails DB?
Re: Extract thumbnail from catalog.
not easy to extract, the BLOB contains image info, metadata and datas
elegie
Post by elegie »
My hard disk is completely destroyed and unrecoverable, and all I have left are just the db files of xnviewmp (xnview.db, thumb.db).
I would like to extract at least some of the image files by any means possible, is there any good way?
elegie wrote: Wed Jan 31, 2024 4:45 am I would like to extract at least some of the image files by any means possible, is there any good way?
Only thumbnails will be possible
elegie
Post by elegie »
Then, how can i extract thumbnails? I just want thumbnail files.
to show thumbnails stored in catalog you can use 'All' in catalog filter panel. Extract them is not easy
