Hi, i encounter incorrect view with specific transparent image
How to reproduce
You can download the image here and open with xnview mp latest version (windows 10 64 bits)
https://drive.google.com/file/d/1uClAjr ... sp=sharing
For more clearly, you should see the difference between viewing in xnview mp and in other programs like photoshop ,or windows photo viewer ,or google drive preview
Viewing with photoshop (and other programs)
And here 's Viewing with xnview mp
this issue only appears with this image, with other transparent images, it works fine
Thanks
[Solved-not a bug]Specific transparent image problem
gm649
Re: Specific transparent image problem
it looks like you switched On 'Use alpha channel' option (its Off by default)
press CTRL+H (or View>Use alpha channel)
gm649
Thank you very much ,it worksuser0 wrote: Wed May 03, 2023 1:42 pm it looks like you switched On 'Use alpha channel' option (its Off by default)
also i'm not sure why other transparent images work without have to turn ("use alpha channel") off
