1.4.4 - viewer - pan - viewing_area movement after zoom
XnViewMP 1.4.4 64bit
Viewer
split from Panning an image all the way to the left produces glitch
there is definetly some issue, but I cannot reproduce at 100% win scale
also my issues remain only until app is restarted
xnview wrote: Fri Apr 07, 2023 9:34 am I can confirm but if you restart XnView after changing setting, it works correctly
0. set win scale >100%, eg 150% in my case
Issue A
1. run clean portable XnViewMP and make app window small (see screenshots)
2. open test image
plane_4.zip
(32.34 KiB) Downloaded 156 times
3. zoom to 200%
4. press f12 to open Settings
- set 'High zoom quality' to Zoom-in
- tick 'Zoom on HiDPI.." checkbox
press OK
5. right click on image and move it to the top left corner
dotted_viewing_area in pan tool will move offscreen
Issue B
6. close XnViewMP instance from issue A
7. run XnViewMP again
8. open test image
9. zoom to 200%
10. press f12 to open Settings
- untick 'Zoom on HiDPI.." checkbox
press OK
11. right click on image and move it to the bottom right corner
dotted_viewing_area in pan tool will not move past invisible border (marked red)
Related
Re: 1.4.4 - viewer - pan tool - viewing_area movement after zoom
the 2 issues are no more present after a restart, right?
xnview wrote: Tue May 09, 2023 9:59 am
correct, after app restart - no issues
Re: 1.4.4 - viewer - pan - viewing_area movement after zoom
fixed in 1.5.0b1
