1.4.4 - viewer - selection - status bar does not update after ratio change
XnViewMP 1.4.4 64bit
Viewer - selection
2. open any image
3. press A for free selection ratio
4. make random selection (it should not match image aspect ratio)
5. press D to lock selection to image ratio
selection will resize, but status bar info does not update untill you resize/move selection
Re: 1.4.4 - viewer - selection - status bar does not update after ratio change
This problem is supposed to be fixed in XnView MP 1.4.5. Please check and confirm the bug fix here.
fixed in 1.4.5
