Custom filter always selected.
FKCapitalism2
Post by FKCapitalism2 »
If i select filter "All" and switch folder filter goes back to "Custom".
Clarification, only menu option always shows "Custom", currently applied filter is still the one you select so XnView MP is still filtering by filter "All".
Same problem regardless you change filter in Filelist toolbar or in View > Filter By
P.S. Pressing filter yellow funnel icon on Filelist toolbar scrolls up the thumbnails window, whats the purpose of this?
Re: Custom filter order always selected.
Custom is used when you have made a custom sort in the folder, (.XnViewSort file)
FKCapitalism2
xnview wrote: Fri May 05, 2023 2:20 pm Custom is used when you have made a custom sort in the folder, (.XnViewSort file)
what sort order has to do with filter?
Sorry. When a .XnViewSort exists, 'Sort By' go to Custom but not Filter.
FKCapitalism2
xnview wrote: Sun May 07, 2023 1:37 pm Sorry. When a .XnViewSort exists, 'Sort By' go to Custom but not Filter.
But this topic is about Filter, not sort order.
yes but Filter is never changed when selecting a folder. In the new folder do you have .XnViewSort ?
FKCapitalism2
When i reported this bug XnView MP was not updating file Filter menu to currently selected one, always highlighted "Custom" option, even though another file filter was applied. However now it started working again, i keep monitoring this and see if happens again.
xnview wrote: Mon May 08, 2023 8:21 am In the new folder do you have .XnViewSort ?
Don't have no .XnViewSort on in folder where i see problem with file filter.
I am not following .XnVewSort is about sort order, how is it related to file filter?
