XnViewMP 1.4.4 64bit
Batch convert - add mask
background is partially visible in 4bit image
1.4.4 - batch convert - add mask - background is partially visible in 4bit image
Re: 1.4.4 - batch convert - add mask - background is partially visible in 4bit image
your image file has transparency, it's the same with 32bits image file
hm, why not like this?
- a (default settings)
- actual - transparency bleeding through mask
- expected - solid mask
- b ("use mask as alpha" enabled)
- actual - transparency lost
- expected - transparency preserved
