[feat] - viewer - cache - image does not updates on revisit
XnViewMP 1.4.4 64bit
Viewer - cache?
0. have 2-3 images in folder*
2. open 1st images in Viewer
3. edit and save 1st image in external app (eg mspaint)
4. in xnview Viewer goto next image, than return to 1st
image will not represent changes
5. press Return to open Browser mode
thumbnail/preview will show modified image
*if you have >=4 images, than 1st images will be updated on revisit if you scroll to 3rd image.
Expected behaviour
it is absolutely OK not to update opened image live,
but I guess it shall update on revisit
UPD
disabling "Keep current image" fixes this behaviour
(Settings>View>Misc)
Related
Preview Refresh On Live Changes to Image Data
masterjp
Re: 1.4.4 - viewer - cache - image does not updates on revisit
Post by masterjp »
I recognized the same thing during my work with adobe photoshop elements.
The only way to refresh the browser is to close the browser window of xnview.
Maybe it could help to view another folder and go back to the previous folder with the changed picture.
Post by michel038 »
In Settings > View > misc , by disabling cache options, perhaps this "bug" will disappear ?
- "Read one image agead" and " "Keep current image"
thanks, michel038,
it looks like it caches up to 3 last openned images,
if so, the proper name should be something like 'Cache last 3 images'
masterjp
Re: [feat] - viewer - cache - image does not updates on revisit
Post by masterjp »
Thank you for the hint.
