Draw - objects - add copy&paste functionality
XnViewMP 1.4.5 64bit
Draw
Suggestion A - objects within Draw
within Draw dialog
  • add functionality to cut, copy and paste objects (eg shapes, text) via CTRL+X/C/V
  • add functionality to copy objects by dragging with CTRL
Suggestion B - images from Clipboard
It is not possible to reposition/transform image pasted into XnViewMP.
Adding this functionality to Draw can be an easy solution.
The result of pasting (via CTRL+V) can be the same as adding image via 'Add watermark' tool
Related
Hakim Antoine Said
Re: Draw - objects - add copy&paste functionality
Post by Hakim Antoine Said »
with due respect, i think this function is NOT necessary
Always Keep Going :wink:
