[feat] - viewer - go to xy location - does not work
XnViewMP 1.4.5 64bit
Viewer - go to x,y location
Issue
I assume it shall move cursor(or selection?) to the desired position, but nothing happens.
Try to set 10,10 coordintes and press OK
- limit max value in X/Y from 999999 to image dimentions
- either do not allow to enter letters into textbox or filter them out
Re: 1.4.5 - viewer - go to xy location - does not work
it moves the center of image to x,y.
Re: [feat] - viewer - go to xy location - does not work
ah, ok, its 'Pan to coordinates'
Go to a specific X,Y coordinate in a loaded image
