Configuration File Saved ???
Post by Hakim Antoine Said »
Hello Guys :)
When i Am Configuring The Entire Software To My Needs
Where is ALL That XnView MP Configuration Stored :?:
i Know There´s A File Where ALL The Configuration is Saved, But Where is it :?:
´Cause if Something Happens, i Will Be Able To Use That File, And Thus i Save A Lot Of Time Spent Configuring The Software Again :x
i Want All The Changes That i Made To The Software And Apply it To Another PC To XnView MP, The Configuration That i Made On Browser Layout, As Well As The Preferences That i Adapted To My Needs, Etc... Where is That File That Saved All That Configuration That i Made To XnView MP
:?: i Need it Please :wink:
Thanks in Advance :!:
Cheers :D
Always Keep Going :wink:
Franky
Re: Configuration File Saved ???
Post by Franky »
It's indicated in the parameters/integration/paths
Hi Franky, i Appreciate For Replying :wink:
But Could You Please Be More Clear :?:
Which File is it :?: Or... Which Files Are They :?:
Please Explain it To Me in More Detail, Thank You Very Much :!:
Franky
Post by Franky »
As you asked, the path of the Ini file can be found here
Apparently i Already Knew About That Route But i Wanted To Be Completely Sure, And Now i Am Thanks To You, Thank You Very Much Franky :wink:
