Program opens with 100% zoom on image.
FKCapitalism2
Post by FKCapitalism2 »
When double clicking image in explorer XnView Mp started to open images at 100% zoom even though i set Tools > Settings > View > Auto image size from Last Used to Fit image to Window.
I found that this problem related to option lockZoom that somehow got set to true inside xnview.ini, not sure what option in GUI that line represents?
Propheticus
Re: Program opens with 100% zoom on image.
Post by Propheticus »
When in viewer: menu item "View > Lock zoom" perhaps?
I do not see your behaviour. The lock zoom actually doesn't seem to do anything at all here. I can still zoom in and out and other images opened from the browser view are shown in normal fit-to-window fashion.
FKCapitalism2
Propheticus wrote: Wed May 17, 2023 10:23 am When in viewer: menu item "View > Lock zoom" perhaps?
Just tested it on v1.4.5.
Deleted my config completely and then in new config generated after first launch of XnView MP i changed lockZoom = true and image i loaded by double clicking in windows explorer opened in 100% zoom.
