1.4.5 Sort by "Type" is broken
FKCapitalism2
In 1.4.4 Sort by Type worked okay, updated to v1.4.5 and its not working anymore, ARW and JPG are mixed together.
Re: 1.4.5 Sort by "Type" is broken
FKCapitalism2
Yes its fixed.xnview wrote: Fri Jun 16, 2023 4:08 pm This problem is supposed to be fixed in XnView MP 1.5.0 beta. Please check and confirm the bug fix here.
FKCapitalism2
Sort by type is broken again in 1.5.0 Beta 4.xnview wrote: Fri Jun 16, 2023 4:08 pm This problem is supposed to be fixed in XnView MP 1.5.0 beta. Please check and confirm the bug fix here.
No problem here? could you post some screenshots?FKCapitalism2 wrote: Tue Jul 04, 2023 2:44 pmSort by type is broken again in 1.5.0 Beta 4.xnview wrote: Fri Jun 16, 2023 4:08 pm This problem is supposed to be fixed in XnView MP 1.5.0 beta. Please check and confirm the bug fix here.![]()
FKCapitalism2
I think i made a wrong judgement.xnview wrote: Wed Jul 05, 2023 6:28 amNo problem here? could you post some screenshots?FKCapitalism2 wrote: Tue Jul 04, 2023 2:44 pmSort by type is broken again in 1.5.0 Beta 4.xnview wrote: Fri Jun 16, 2023 4:08 pm This problem is supposed to be fixed in XnView MP 1.5.0 beta. Please check and confirm the bug fix here.![]()
