1.4.4: missing xmp in search
missec
Post by missec »
XnView: MP 1.4.4 - 64 bit (Portable version)
OS: Windows 10 - 64bit
Missing XMP dropdown in search menu
Effect: missing ability to add search conditions from xmp metadata fields which was previously working in version 1.4.3
1. Tools > Search (or Ctrl-F)
2. Select "Add>>"
Actual behaviour (bug): Option to Select XMP fields is missing from Search dropdown menu. :bug:
Expected behaviour: Previously XMP fields were able to be selected from the menu.
missing search.png (185.96 KiB) Viewed 1126 times
Re: 1.4.4: missing xmp in search
missec
Post by missec »
This is fixed in 1.5.0 beta 3. Thank you! :)
