Hakim Antoine Said
Post
by Hakim Antoine Said »
Hello Every1...
The Button is Not Displayed Correctly
i Use A Theme (Skin), Which Does Not Let Me See The Buttons Well,
i Recommend That The Buttons Be White,
With That The Bug is Fixed Quickly
IMPORTANT:
The
Theme Called
Black,
is Responsible For Not Being Able To Correctly Display
Almost All Pop-Up Windows
By Putting 90% Black Colour And Not 100% Black Colour, All The Bugs With The Black Theme Are Fixed
is There A Way To Do That Manually
i Only Use Black Theme ´Cause i Don´t Like Other Themes, Black Theme is The Best
Cheers
Always Keep Going
Post
by xnview »
Thanks to your detailed description I can reproduce
the problem.
Hakim Antoine Said
Post
xnview wrote: Wed May 17, 2023 7:08 am
the problem.
Hi Pierre, Thanks For Replying
i Shall Show You 1 Example
With
Dark Theme We
CAN See Everything
CLEARLY
BUT... With
Black Theme, We
CAN NOT See Anything
We Can Not See The Buttons,
AND Same For The Video Player
Black Theme is The Best Theme For XnView MP
i'll Show You The Examples With Attachments
Thank You Pierre
Always Keep Going
Post
by xnview »
This problem is supposed to be fixed in
XnView MP 1.5.0 beta. Please check and confirm the bug fix here.
Hakim Antoine Said
Post
xnview wrote: Fri Jun 16, 2023 4:07 pm
new message
the squares can be seen but you have to strain your eyes a lot to see these squares
there is still a long way to go before the squares are visible without straining the eyes so much
so... it's not fixed yet, it's only fixed the video player buttons
Always Keep Going
Post
by user0 »
1.5.0b1
Post
by xnview »
yes will be fixed in b2
