[macOS] "Open With" XnViewMP for HEIC files
AndreasW
Post by AndreasW »
On macOS, when you right-click a HEIC file in the Finder and then go the the "Open With" menu, XnViewMP will not appear in the list of programs that can open this file. Please add XnViewMP to that list. I consider this a bug, as XnViewMP does support HEIC.
Re: [macOS] "Open With" XnViewMP for HEIC files
ok, will be added
AndreasW
Post by AndreasW »
I see that the problem is fixed for HEIC files in XnViewMP 1.5.0 beta 3. Thank you very much!
Unfortunately, the same problem also (still) exists for WEBP, AVIF, and SVG files. Could you please fix that problem for these file types too?
ok
AndreasW
Post by AndreasW »
It's fine now in beta 4. Thank you very much!
