1.4.5 - viewer - clean metadata - does not delete gps
XnViewMP 1.4.5 64bit
Viewer - clean metadata
does not delete GPS
1. open .jpg with GPS in Viewer
2. open 'Clean metadata...' (View>Clean metadata)
- select GPS only
- press OK
3. press CTRL+S to save image
no GPS data will be deleted
ps: in Browser it works fine.
Related
Re: 1.4.5 - viewer - clean metadata - does not delete gps
1.5.0 well.. it cleans GPS, however:
- metadata is not affected until image is saved (that is not acceptable for non-loseless formats), also
- image become dirty once OK pressed in dialog
it shall work EXACTLY the same way it works in Browser
it always shall Write, not Apply because this is delete action on existing metadata
(not the case when we have image in buffer+new metadata that can be saved in new format)
ps: for the sake of sanity - Metadata - unify 'Clean metadata' dialog
user0 wrote: Sat Jun 17, 2023 5:27 am it shall work EXACTLY the same way it works in Browser
I disagree, 'clean metadata' works not only on jpeg but on image datas
what "image datas" you mean, file timestamp?
why Viewer's Clean metadata is different from Browser's?
my usecase - I would like to delete all metadata from image (eg jpeg, png, gif, webp) from any place of the app (viewer, browser, batch).
While doing it I would like to keep image data untouched (unresampled/unconverted/etc).
Currently I cannot do it from Viewer as it forces me to manually resave file after cleaning (not saying that it does not clean all metadata), that triggers image resampling for default lossy settings of some formats.
this is how I see it )
where am I wrong?
user0 wrote: Sat Jun 17, 2023 3:47 pm what "image datas" you mean, file timestamp?
It's like 'Edit IPTC/XMP', you change the metadata of loaded picture, not the file.
than it shall have the same Write and Apply buttons as Viewer's 'Edit IPTC/XMP'.
hm.. I just noticed that Write in 'Edit IPTC/XMP' makes file dirty.
Imho, it should not, because it pointless nd confusing - if you press "Don't save" new metadata will not gone anyway, its already written into the file.
user0 wrote: Mon Jun 19, 2023 8:26 pm hm.. I just noticed that Write in 'Edit IPTC/XMP' makes file dirty.
I can't reproduce, do you have a way?
xnview wrote: Tue Jun 20, 2023 7:20 am
i will make separate post:
1.5.0 - viewer - metadata - Edit XMP makes file dirty
