1.4.5 Thumbnails not updating after changes made in XnView
danielpup
Post by danielpup »
Hello, a while ago all thumbnails for photos/drawings (basic jpgs and pngs) stopped updating when I edit them in XnView. For example rotating them or cropping keeps the old thumbnail, but editing the same way in photoshop does change it. Only I mostly do it in XnView so it's bothersome...
Doing a copy/paste action makes the thumbnail change btw, but I don't wanna do that and change the name and delete original file everytime.
I looked thru the forum here and tried switching different things in options, but nothing seems to work! I even downloaded older version, nope. I have no idea what could cause it because before it worked just fine, after every edit and save thumbnails would immediately refresh. Any ideas? Thanks!
Re: 1.4.5 Thumbnails not updating after changes made in XnView
really strange, do you have tried 'View>Rebuild Thumbnails'?
danielpup
Post by danielpup »
Yep, also clearing whole catalouge of minatures, then editing photos and clearing it again to see if it loads again correctly, but it doesn't. From what I understand it's some sort of cache issue? It surprises me that they only load correctly when I create a new copy of the file. Idk, I switched all possible settings connected to it, no luck.
I have another program as well for minatures, sage thumbs for building psd ones, but I uninstalled that one too when this problem appeared and nothing changed (also it worked together fine before).
danielpup
Post by danielpup »
Here you go, the photo is rotated horizontally and cropped. I added the screenshot of how the thumbnail looks for me. Oh btw! When I view the list of files within the XnView it shows correctly. So it's a purely outside of the program issue.
how do you see it outside XnView?
danielpup
Post by danielpup »
the first photo is how it looks on my desktop and in any open window, any type of preview size.
i don't understand, in XnView the file looks good, but the screenshot of your desktop it looks good too
danielpup
Post by danielpup »
Maybe this wasn't clear enough of a screenshot so I will show you a much clearer example. Happens every time I edit sth in xnview, doesn't change when refreshing or closing window, nor after cleaning or refreshing thumbnails in xnview settings.
do you have Settings>General>Keep original date/time file saving?
danielpup
Post by danielpup »
yes all the options are checked under it
Perhaps windows doesn't detect file change, unset it
danielpup
Post by danielpup »
Wait that actually fixed the problem! But what are the consequences of unchecking it? Will I lose some sort of metadata when editing pics now?
danielpup wrote: Sun Jun 04, 2023 12:30 pm Wait that actually fixed the problem! But what are the consequences of unchecking it? Will I lose some sort of metadata when editing pics now?
No, the file's date will change
danielpup
Post by danielpup »
I see, that's not too bad, but do you have any idea why windows suddenly stopped recognising the changes? Is it a XnView bug or it's some new windows update that messed things up?
