1.4.5 - batch convert - modifying disabled action triggers recalculation
XnViewMP 1.4.5 64bit
Batch covnert
To reproduce
1. open relatively large (to slow down effects calculation) image in Batch convert
Issue A
2. remove any existing actions
3. add few actions
- disable some of them
- leave at least one enabled
4. modify any disabled action
app will do full recalculation showing progress bar as if this is enabled action
Issue B
2. close Batch convert and open it again
3. modify any existing disabled action
app will do partial recalculation showing progress bar
Expected behaviour
modifying disabled actions should not trigger any recalculations
Re: 1.4.5 - batch convert - modifying disabled action triggers recalculation
fixed in 1.5.0
