1.4.5 - settings - catalog - fix Build thumbnails dialog
XnViewMP 1.4.5 64bit
Settings - Catalog
Build thumbnails dialog need some tweaks
Issue A
progress bar does not reach right end
Issue B
dialog automatically resizes on long filenames, but does not return to normal size after
also its better to left-align filenames
Issue C
this dialog should not be resizable at all, however it is possible to manually resize it
masterjp
Re: 1.4.5 - settings - catalog - fix Build thumbnails dialog
Post by masterjp »
What bothers me a little, however, is the dynamic enlargement of the window, although the file names are sometimes only minimally longer. With JPEG files, the display of the long name is sometimes so fast that the enlargement of the window for a few file names seems unnecessary.
Furthermore, it would be nice if the abort button was placed at the bottom centre of the window.
But it is more of a cosmetic problem.
PC: Intel 8700k + Asus Z370-F + 16 GB RAM G.Skill + Asus RTX 3050 OC + Samsung SSD
OS: Windows 10 Pro 64bit 22H2 |
GFX: XnViewMP 1.8.7 | XN-View 2.52.0 | XnConvert 1.104.0 | Adobe Photoshop Elements 2024 | Elements XXL 11 | Paint.Net 5.1.7
masterjp wrote: Mon May 22, 2023 4:28 pm it would be nice if the abort button was placed at the bottom centre of the window.
commit buttons shall be right-aligned
masterjp
Post by masterjp »
Okay, there is a basic style guide for windows or recommandation.
user0 wrote: Mon May 22, 2023 2:50 pm Issue A
Issue B
Issue C
With Qt, all dialogs are resizable...
1.5.0b1
fixed for "Build thumbnails..." dialog (runs after "Rebuild thumbnails" button is pressed)
BUT I suddenly same issues in:
- "Building catalog entries..." dialog (runs after "Import folder..." button is pressed) has the same issues
not sure if it deserves separate post
user0 wrote: Sat Jun 17, 2023 4:05 pm 1.5.0b1
yes please a separate post
