Different "Show As" views for different Folders
josedumoretzsohn
If this is posssible, and considered to be a good idea, I suggest XN MP enables a different "Show As" view for each folder, enabling the simultaneous coexistence of folders shown as "List" and, for instance, as "Image and Comment". Therefore, folders containing only .txt, .docx, .html, and other text extensions can be "Shown As" list, while the folders containing images will show image extension files. Folders containing both image and text entension files would shown both as "Image".
Re: Different "Show As" views for different Folders
tbh, this is one of the most annoying features of windows' file explorer
mainly because it does not allow to set view template (there are 5 of them) for all folders at once.
