Video player hide/show playbar shortcut key.
FKCapitalism2
When opening video then pressing i press F11 to go full screen, in order to hide playbar from internal player there is no key, have to use mouse, hotkey would be nice also.
Hakim Antoine Said
Re: Video player hide/show playbar shortcut key.
I don't understand your request
the player is not hidden, it is always visible, with the mouse you cannot hide it either
Always Keep Going
yeah, there is default playbar appears on videos in fullscreen
better to disable it for video as it does nothing
FKCapitalism2
When in full screen play/seek bar shows on bottom on screen, it can be turned off, if you right click on video and uncheck show play bar, can we have a hotkey for this action to perform it faster.Hakim Antoine Said wrote: Thu Jun 01, 2023 8:24 pm I don't understand your request
i Got itWhen in full screen play/seek bar shows on bottom on screen, it can be turned off, if you right click on video and uncheck show play bar, can we have a hotkey for this action to perform it faster.
in full screen right click it doesn´t work for me, only in view mode i can do right click and hide play/seek bar, it´d be great add a shortcut for this action, for both (view mode and full screen)
Always Keep Going
Please we need a shortcut for this option
Always Keep Going
