Selected JPEG save quality not used
den41den
Post by den41den »
For some time already, I cant change/apply JPEG quality in the save dialog. I move the slider, press save, however actual quality does not apply. The resulting file is different from what is set. It seems that other options like sampling/optimization do apply, however.
Can you please help to reset/repair?
It used to work okay before.
Thanks
Denis
Re: JPEG save quality does not apply
Is the save option 'Use estimated quality (if possible)' enabled?
Note: I am in Linux where the interface may be different, and my interface is temporarily set to French!
den41den
Post by den41den »
cday wrote: Mon May 29, 2023 1:02 pm Is the save option 'Use estimated quality (if possible)' enabled?
Yes, it is enabled
den41den wrote: Mon May 29, 2023 1:26 pm
Yes, it is enabled
Then isn't that the problem?
